![benArrayx](/data/avatars/m/10/10856.jpg?1448971110)
benArrayx
- Messages
- 157
- Vehicle
- T6 Cali On Order
Hi all, i have a problem with my T6 Ocean after having made a short circuit from the leisure battery under the front seat to the engine battery, mistakenly connecting positive leisure to negative engine. Sparks flew briefly and then stopped. After this, the camper control unit was dead unless the engine was on, or the van was plugged in to the mains.
I'm now with a mechanic friend, we found 2 blown fuses, the first one the second leisure battery in the boot (75A), on the positive terminal, we replaced this, the second in the fuse box underneath the engine battery (100A), also replaced.
We have checked every single other fuse behind the bottle holder in the centre console, underneath the seat where the battery is, and in both engine compartment fuse boxes, all are ok.
The problem we are left with, is that the camper control unit will only turn on with the engine off, if we make a connection from the under seat battery negative terminal to the van body. With this connection made and no engine on (no ignition either), the camper control unit comes on and everything works normally, except for a weird 4A-15A constant drain on the leisure batteries which obviously shouldn't be there.
Having looked at the electrical schematics available on the download section, it's clear that the battery under the seat should be connected to earth (ie the van body if I understand correctly, I'm not an electrician!), but for some reason seems not to be, given that without making an extra connection the control unit is off, and making an extra connection turns it on. The negative cable between the two leisure batteries is intact, we tested for continuity of that cable.
Does anyone have any idea of what could be the problem with the under seat battery connection to earth after having short circuited the under seat battery with the engine battery and having fixed the blown fuses?
We have connected to van diagnostics (ie via OBD) but there are no errors.
Any help really appreciated![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
