@Webbah_in_Switzerland, who posts here, has one in Switzerland (obviously ...) but I unable to find the details via search. You might have luck for example using a Google search.
Thanks mate,
I have some contacts that are fabricators so could possibly modify one but rather buy some thing 'off the shelf'
There is also the legality/insurance issue to consider
That was quick, @Webbah_in_Switzerland!Here’s the one I use:
SpaceMaker der Adapter für deinen Fahrradträger | pick-up-and-go
Mit dem SpaceMaker können zwei Fahrräder einfach 90° weggeschwenkt werden und bieten so vollen Zugang zum Heck deines Fahrzeuges.www.pick-up-and-go.ch
Thank you for posting.
What is the connection type/style for both to the vehicle and to the rack ?
Here in the UK we have this style of tow ball
Perfect
I have messaged them to see if they can supply one to the UK.
Do you have any pictures of it in action ?
Thanks guys
Perfect
Thanks guys
Looks perfect, exactly what I am after
I might just road trip over and collectSee why they say, otherwise my mechanic here works closely with Leighton Vans in the UK so he might be able to ship one there or something. He’s crazy busy though so that’s a last resort.
I can't see anything listed on their site
They have confirmed it does not fit a VW as it sticks out passed the side of the van (Cyclist sweeper).
As in the quality isn't great ?Those Memo ones are cheap and cheerful. If it’s too wide the just cut the arms and chop a bit out then weld it up again.
No just as in not as nice design and less aesthetic than the Swiss made one.
The Memo is just box section powder coated so easy to modify and make nice. It’s perfectly fine , well made and simple.
I’ve studied them at length with a view to making my own. I considered using a Memo as a donor.
Personally I don’t like the double tow ball design, rack on a rack approach especially when you’re using a heavy folding ebike rated rack on the swing out unit.
Using a swing out unit means you’ve solved the bikes-in-the-way-of-the-door problem so why add a folding rack as well. Non folding ones are available obvs.
In my op, there is a huge gap in the market for a lighter rack with a better method of mounting the bikes to the rack and certainly something a bit less obtrusive.
