Stu said:Lots of people tend to use the cheapo (<£15) single burner units that run from the aerosol can sized gas. These are fairly easy to clean, disposable when you can't be arsed to clean it and the gas fairly cheap all combined with being small and convenient.
I had one of those Camping Gaz two burners + grille units and they aren't great to be honest.
Stu said:I see your point but if you want to use 907 then you either need another cylinder to take with you or you'll be pulling your van apart every time you want to cook something to get your 907 out.
The aerosols are small to carry and you can find them easily in the EU. If you need two burners buy two singles?? It's not going to be any bigger than the Camping Gaz unit and being two smaller parts may be easier to pack.
I mean this style (currently £10 in Go Outdoors) -
Custardtart said:I've used a coleman dual fuel twin burner for years.
Pros:
Very powerful
Very easy to find fuel anywhere you go
Cheap to run
Never let me down
Cons compared to gas (in my opinion):
Petrol isn't nice stuff to deal with
Not as simple to use
Could be a good option for an outdoor stove and insurance against running out of gas.
TravellinJones said:I liked the idea of a common gas can size - thinking we will be better insured against running out. We will use our van mostly for wild camping in NW Scotland so are aiming for maximum levels of self sufficiency. So - I've invested in one of these: http://www.amazon.co.uk/Campingaz-Super ... B0002DF17W
Plan is to carry a 'spare' 907 for the Cali - and use if for this when we cook outside. I envisage using the outside stove for the smelly stuff (hopefully catch a few mackerel...) and the inside stove for the carbs...
That said - this is a system/theory that is yet to be proven so I defer to those seasoned campers recommending the single burner stoves w/ aerosol style gas cans - they are very compact and at £10 no great loss if it turns out they don't suit your needs.
Also, I guess my solution this isn't the answer for you if you're after a 2-burner hob (unless you fancy lugging 3 x 907's around with you?) but I just though I'd throw the link out there as may be of interest to somebody else.
