Cadac Bayonet Gas Cartridge Adaptor is the perfect solution when wanting to turn a clip in bayonet type gas supply into a threaded EN417 gas cartridge
This works with Threaded Cartridge Regulators and Safari Chef 30 HP but is not just limited to this, if you have a different brand of gas BBQ that needs threaded EN417 type canisters then this adaptor will allow you to use them up!
Simply push and twist fit onto your canister and screw the other side of the adaptor to your BBQ to use.
Gas bottles in the pictures are not included.
