The Carri Chef is a luxury all-in-one gas barbecue with a large cooking surface of ø 46cm for cooking home or away.
The powerful stainless steel burner together with the piezo ignition ensures you get the desired temperature. With the lid/dome closed you create an oven, ideal for baking or stewing. The BBQ grid is provided with CADAC GreenGrill coating; this completely PFOA-free, ceramic coating guarantees healthier and cleaner cooking. Thanks to the integrated heat spreader under the grid, the heat is well distributed over the entire cooking surfaces.
Cleaning has also been considered; you only remove the surfaces from the barbecue and clean it with soapy water.
The aluminum legs of the Carri Chef are easy to unscrew and tighten. The condiment tray between the legs offers extra space for barbecuing and ensures that the BBQ is sturdy and stable.
The BBQ is easy to assemble, clean and store in the supplied carrying bags which makes this the ideal barbecue for both the home and to take on vacation.
The Carri Chef BBQ / Plancha comes with a pot stand, BBQ/Plancha pan, and dome. For even more cooking pleasure, the Carri Chef can be expanded with many optional accessories like the Pizza Stone or Paella Pan – this way you put together your ideal barbecue!
Note: gas bottle, pressure regulator, and/or Power Pak are not included.
- Heat-resistant dome handle (ø 50cm)
- Automatic push button Piezo ignition
- BBQ/Plancha made from aluminium for even heat & maximum cooking
- Porcelain enamelled dome with stainless steel heat deflector
- Dome clips on back and acts as a windshield & splash-back protector
- Light-weight anodised aluminium legs
- Carry bags included
- Incl. Pot Stand, BBQ/Plancha and Dome
- 2 year warranty
Dimensions
- Width: 70 cm
- Height: 93 cm
- Depth: 70 cm
Technical info
- Approximate weight: 12 Kg
- Total heat output: 3.7 kW
- Total average gas consumption: 270 g/h
- Average operating pressure: 28-37 mBar
8910-82-EU
