Cadac Soft Soak 2 Cook Square Soaking Bowl – New for 2023
£14.49 Inc VAT
Only 1 left in stock
Found this item cheaper?Environmentally friendly, and sized to perfection, our Soft Soak 2 Cook takes the hassle out of cleaning.
Soaking your grill plates before washing means less time spent on cleaning and more time for you to enjoy the outdoors. No mess, no fuss! Fully submerge the Grill Plate/s surfaces from the Cadac 2 Cook 2 and 2 Cook 3 ranges for easy cleaning and soaking after use. The 2 Cook Soft Soak can take both Grill Plates at the same time.
Made from a heat-resistant silicone, the soft soak is durable and heat resistant to 220 °C. For best results pour hot soapy water into the Soft Soak, add the Grill Plates upside down and leave to soak for 60 minutes to allow all burnt-on bits and grease to lift. Then remove and simply wipe clean the grid or rinse with clean water.
By using the Soft Soak your Grill Plates and cooking surfaces do not become damaged like they can with the use of traditional scrubs, brushes and cleaning products. By leaving to soak in this soft, protected environment burnt-on bits and hard to remove residue will loosen without the need to scrub and scrape the Grill Plates coating off.
The unique but durable silicone is stackable and foldable for storage, wrap it around the grill/s during storage or when not in use, making it convenient and easy to use wherever you are.
