VW California
Caravan
Drive-Away Awnings
Tents
Cadac Trio Power Pak Gas Supply - Quick Release The housing has a removable back cover, which makes it easy to insert and click the 3 x 227g gas cartridges (not included) into place. The gas hose of the Trio Power Pak body and connection to the BBQ can easily be (dis)connected due to the integrated Quick Release couplings on each end. This way you (dis)connect the gas hose with just a single click. With the Trio Power Pak you will get around 7 hours of cooking time for a small barbecue. A convenient storage bag is also included.
Cadac Trio Power Pak Gas Supply – Quick Release
£49.99 Inc VAT
In stock
Found this item cheaper?
The Cadac Trio Power Pak with Quick Release Connector replaces the need to have a bulky gas cylinder.
This lightweight, portable gas supply is ideal for camping, picnicking, and caravanning.
With the Trio Power Pak, you will get around 7 hours of cooking time for a small barbecue. A convenient storage bag is also included.
Not only is this perfect for smaller BBQs, but it also runs well on larger BBQs/Cadacs.
  • Weight: 1.6kg
  • Dimensions: 16cm x 25cm x 25cm
Cadac
CADAC barbecues, portable grills & BBQ accessories are known for their outstanding quality, versatility, and user friendliness.
Be the first to review “Cadac Trio Power Pak Gas Supply – Quick Release”
£49.99 Inc VAT
