Sale!
Caravan Regulator c/w 10mm Adaptor for Copper Pipe
£17.99 Inc VAT
Only 1 left in stock
Found this item cheaper?
- Micro 30mb Motorhome and Caravan Regulator with a 10mm straight outlet.
- Small and compact
- Conforms to standard 12864 annex D,
- For Caravan & Motorhome use only,
- Suitable for all liquified petroleum gases, propane & butane
- Comes with a 10mm outlet already fitted
- W20 (pigtail type) fitting on the inlet.
- Regulating pressure: 30 mbar (35 mbar, min 30 mbar)
- Required leak test point fitted.
R43010
Weight | 0.86 kg |
Dimensions | 43 × 32 × 4 cm |
