VW California
Caravan
Drive-Away Awnings
Tents
Caravan Regulator c/w 8mm Adaptor for Copper Pipe
£19.99 Inc VAT
Only 1 left in stock
Found this item cheaper?
SKU: 731275718641 Categories: ,
  • Conforms to standard  12864 annex D,
  • For Caravan & Motorhome use only,
  • Suitable for all liquified petroleum gases, propane & butane
  • Supply pressure: 0.3 16 Bar
  • Regulating pressure: 30 mbar (35 mbar, min 30 mbar)
  • Inlet fitting 20×1.5 m left hand thread
  • Outlet Fitting; Compression fitting 8mm
R43008
Weight 0.86 kg
Dimensions 43 × 32 × 4 cm
Pennine Leisure Supplies
Caravan, Motorhome, Campervan Conversion and Camping Accessories, Spares & Leisure Appliances.
Be the first to review “Caravan Regulator c/w 8mm Adaptor for Copper Pipe”
You may also like…
£19.99 Inc VAT
