The simple Event Shelter from Coleman is a practical solution offering great shelter from the sun and light rain whilst hosting your outdoor event! With a solid frame this 12 x 12 event shelter is simple to pitch and is great for use in the garden or at a campsite where space is limiting factor!
- Flysheet: Polyester PU transparent Coated
- Poles: Steel
- Living area: 13.32m²
- Headroom: 218cm (centre), 169cm (sides)
- Polyester carry bag: Rectangular with zipper opening
- Pack size: 87 x 23 x 30cm
- Weight: 17kg
- Water column: 1000mm
WeatherTec™ -offering comfort and protection when enjoying the outdoors
WeatherTec™+ system – an assessment of our tent’s resistance to the elements
WeatherTec™+ is the Coleman assessment of how ‘weather proof’ we gauge our tents and shelters. There are many factors which influence the performance of tent in tough weather conditions. Coleman use the latest technology and a rigorous testing regime to ensure that we keep you protected at all times – whatever the weather.
One key area we examine is a tent’s ability to repel water. A fabric’s waterproof properties are measured using a rating called hydrostatic head. If a tent has a hydrostatic head of 3000mm it means that a 3 metre column of water can be placed on its surface before any drops will show through the underside of the fabric.
The areas of the tent rigorously assessed within WeatherTec™+ system include: fabrics, flysheet and ground sheet seams and zipper water tightness.
UV Guard™ Sun Protection
Certified laboratory testing proves Coleman® UVGuard™ protection fabrics with an SPF50 provide excellent protection against the sun’s ultraviolet rays. Proper use of sunscreen combined with shelters made with UVGuard™ protection fabric can go a long way in the battle against sunburn and UV exposure.
Fire Retardant – safety first!
The fire retardant characteristic of our material ensures that the fabric will not flare dangerously out of control and will self extinguish, giving time to escape in the event of an emergency.
Steel Poles
Steel poles are very sturdy and hardwearing, offering increased strength for large structures.
2000034471
