VW California
Caravan
Drive-Away Awnings
Tents
Disklok Steering Wheel Lock Silver Small
Disklok Steering Wheel Lock – Silver – Medium
£143.95 Inc VAT
Out of stock
Email Me When Back in Stock
Full cover car security Disklok prevents the steering-wheel from being cut when under attack in order to remove the security lock.
The UK’s strongest steering wheel lock… Spins on attack.
Disklok is the strongest and most effective full cover steering wheel security lock in the world for cars and light commercial vehicles. For vehicle security, the unique award winning Disklok has a long and proven history of outstanding performance; tried and tested against would-be car thieves, professional independent security testers and authorities. The range was approved and endorsed by Thatcham for two decades, far exceeding all of their minimum requirements. We are now Sold Secure Gold and Secure by Design approved.
The reinforced, all steel construction makes the Disklok an extreme deterrent with its high visibility and reputation for durability, outlasting the attack times of all other steering wheel locks on the market today. The unique advantage it has over the competitors is its ability to spin on the wheel when attacked, preventing steering and damage to the vehicle’s own steering wheel lock.
With Disklok’s reassuringly mechanical attributes, it is the one device you can rely on to deter “keyless entry theft”. Although alarm systems and OBD port locks can be effective, they are hidden and will not deter entry to the vehicle, risking damage and increased insurance premiums. With the Disklok’s fearsome industry reputation, would-be criminals will simply move on to another victim, making this the best all round value investment on the market.
Each Disklok has built in adjustment of 1 inch which allows you to find the perfect size for your steering wheel. When fitted correctly, the Disklok should be loose enough to slide around on your wheel but not loose enough to lift off.
Remember to check your wheel size (diameter) before ordering as this is the small version that will fit steering weheels with a diameter of 39 – 41.5cm
RHDSMLSILDSK
Weight 3.75 kg
Dimensions 65 × 20 × 18 cm
Disklok
Disklok is the strongest and most effective full-cover steering wheel security lock in the world for cars and light commercial vehicles.
Be the first to review “Disklok Steering Wheel Lock – Silver – Medium”
You may also like…
  • Disklok storage bag
  • Disklok Steering Wheel Cover
£143.95 Inc VAT
Discount Code - SALE10
    SUBSCRIBE
