VW California
Caravan
Drive-Away Awnings
Tents
Dodo Mat DEADN Hex Roll Sound Deadening and Insulation
£54.99 Inc VAT
Only 2 left in stock
Found this item cheaper?
SKU: 5060675880272 Categories: ,
Dodo Mat DEADN Hex Roll Sound Deadening and Insulation, an Ideal Quick and Easy Solution for Sound Deadening and Insulating your Campervan Conversion
Dodo Mat DEADN Hex is a self-adhesive, foil backed sound deadening vibration damper. Simply cut, peel & stick Dodo Mat DEADN Hex on the interior sheet metal of any vehicle to destroy unwanted vibrations & structural noise.
Make those panels as dead as a Dodo!
Dodo Mat DEADN Hex has a high-grade butyl compound for better sound deadening & vibration control. To maintain flexibility and ease of cutting we also employ our unique Hex embossing pattern.
Dodo Mat DEADN Hex provides a lower-weight solution for the car/van owner wanting a quiet smoother drive without adding unnecessary mass.  The unique Dodo specification chemistry of the synthetic butyl core effectively deadens panel vibration without the excessive bulk of competitor products.
The distinctive Hex top sheet is purposely designed to aid installation and mould easily on more complex surfaces. This added flexibility allows the Dodo mat to be supplied in larger single sheet rolls for improved fit and cosmetic appearance whilst minimising creases and folds.
To increase installation convenience the product is supplied in one extra large 5.8m sheet (rolled) perfect for custom work and large areas.
Specification
  • Makes metal panels as dead as a Dodo!
  • Large Bulk Roll
  • High Grade Butyl Construction
  • Hex embossed aluminium
  • Very Soft & Flexible For Easy Installation
  • 1.8mm Thick with Strong Adhesive
  • Classic Aluminium finish
  • Stop Rattles, Vibration & Noise
  • Lower Road, Exhaust, Engine & Transmission Noise
  • Heat Resistant from -40°C to +120°C
  • Flammability tested for vehicle interiors ISO 3795:1989
  • Fully Water & Oil Resistant
  • Very Low Odour compared to bitumen and inferior mats
  • Peel & Stick Application
  • Designed in the UK , Manufactured in Europe
  • Roll Weight 11.7kg
  • Supplied as 60cm x 583cm Roll
  • Coverage 3.5sq.m (37.6 sq.ft)
Use on the vehicle floor, doors, roof & side panels
Be the first to review “Dodo Mat DEADN Hex Roll Sound Deadening and Insulation”
£54.99 Inc VAT
