VW California
Caravan
Drive-Away Awnings
Tents
Dometic HUB Weight Bag
£15.99 Inc VAT
Only 2 left in stock
Found this item cheaper?
SKU: 5056446102056 Categories: ,
Pitch your Dometic HUB on hard, stony or sandy ground with ease. Fill the Weight Bag with water or sand and secure to your inflatable shelter, allowing you to securely pitch your HUB wherever you are – even when using pegs is not an option.
  • Durable PVC construction for strong wear resistance
  • Watertight design – fill with sand or water for quick and easy weights
  • Simple assembly with clip and Velcro installation to the HUB
Dimensions
  • Depth 230 mm
  • Height 700 mm
  • Width 230 mm
  • Net weight 0.65 kg
9120001512
Kampa Dometic
Dometic make the world more mobile. Their motivation is to create products with outstanding design for use in recreational vehicles.
Be the first to review “Dometic HUB Weight Bag”
You may also like…
£15.99 Inc VAT
