VW California
Caravan
Drive-Away Awnings
Tents
Dometic Hub Inflatable Activity Shelter
£634.99 Inc VAT
Out of stock
Email Me When Back in Stock
Adapt the HUB to suit your needs. Start with the base shelter and add annexes, mesh panels, wall panels, and connection tunnels to fit SUVs and campervans. Single Point Inflation AIR Frame technology and Quick Pitch straps ensure you are pitched and ready to enjoy the outdoors in no time.
The center of your outdoor adventure
With the Dometic HUB, the possibilities are endless. Pitch freestanding at the beach, on-site with your campervan, or as valuable shelter when off-roading with your 4×4 or SUV. Showcasing the latest innovations in design and function, as well as patented awning technology, the HUB ensures reliable shelter is only ever minutes away. Experience our most versatile awning ever and have the confidence and freedom to follow your own path.
Embrace spontaneity set up camp and get close and personal with nature. The HUB is suitable for every environment; its unique features, durable fabrics, and smart design allow you to travel between the best outdoor spots with ease – ensuring you’re first on the trail when the sun comes up.
Experience more with our most versatile outdoor activity shelter. The HUB’s unique design means it can be used as a gazebo or tent. Add up to three annexes so you can sleep 6 people under one roof. Wherever you’re going and whoever you’re with – the Dometic HUB has you covered. Whether you’re away for the afternoon or a weekend, make your home anywhere.
  • Single Point Inflation awnings inflate from just one external inflation point
  • Use freestanding or zip-on optional connection tunnels to connect to SUVs and campervans
  • Set-up in seconds. Peg, the bottom strap taut and adjust the buckle to apply tension
  • The durable PVC shelter base has been incorporated to resist damage when pitching on hard and stony ground
  • Weathershield™ Pro double coated polyester fabric
  • Generous dimensions maximise the livable space of your pitch
Comes complete with 1 awning; 4 QuickPitch straps; 4 storm straps; 1 2L pump; 1 peg pack; 1 manual; 1 carry bag
Specifications
  • Depth 2300mm
  • Height 2300mm
  • Width 2300mm
  • Connection height min 180.00 cm
  • Connection height max 210.00 cm
  • Net weight 13.80 kg
9120001506
Kampa Dometic
Dometic make the world more mobile. Their motivation is to create products with outstanding design for use in recreational vehicles.
Be the first to review “Dometic Hub Inflatable Activity Shelter”
You may also like…
£634.99 Inc VAT
