Does your caravan have a jacking point? The kojack scissor jack is the answer.
Custom designed brackets allow you to easily and effortlessly jack & level your caravan without the need for drilling your caravan chassis; which can void your warranty. The Kojack scissor jack is suitable for most AL-KO caravan chassis from 1992 onwards.
Kojack Scissor Jack is ideal for lifting your caravan quickly and easily in emergency situations, such as wheel changes. The Kojack Scissor Jack is capable to lift a Safe Working Load of up to 1500kg.
Utilising a mechanical screw and thread, Kojack Scissor Jack is free from oil and is supplied with a scissor jack handle.
Be sure to check out the complete KoJack Lifting and Levelling range.
Kojack Scissor Jack … make light work of lifting your caravan
Specifications
- Rated SWL:1500kg
- Minimum Height:100mm
- Maximum Height:365mm
- Lifting Height:265mm
- Net Weight:4.45kg
- Overall Dimension (Retracted)410 x 100 x 38 (mm)
SJ1500
