VW California
Caravan
Drive-Away Awnings
Tents
Fullstop Kopads Caravan Feet
£11.99 Inc VAT
In stock
Found this item cheaper?
SKU: 5060048882810 Categories: , , ,
kopad attaches to your caravan’s corner steady feet to help spread the load of the when supporting your caravan. This is particularly helpful on soft ground to avoid the corner steadies sinking into the ground or marking the floor underneath them.
Designed in Purple Line’s UK innovation center with durability in mind and manufactured using super-strong composite materials that are resistant to cracking and fading. kopad is part of the kojack range of lifting and leveling products.
The kopad is secured using a metal retaining pin for extra strength.
Each set includes 4 x Caravan feet and pins.
kopad… spread the load.
  • Weight:0.3kg (each)
  • Height:50mm
  • Width:145mm
  • Depth:180mm
  • Securing Pin: Metal
  • Quantity: Set of 4
BF100
Purple line
Purple Line Limited is a UK Based company that designs and manufactures a wide range of products for recreational vehicles.
Be the first to review “Fullstop Kopads Caravan Feet”
You may also like…
£11.99 Inc VAT
