VW California
Caravan
Drive-Away Awnings
Tents
Vango Galli Air TC Low Drive Away Awning
Vango Galli Air TC Low Drive Away Awning Breathable Polycotton
(1 customer review)
£1,399.00 Inc VAT
Out of stock
Email Me When Back in Stock
The Vango Galli Air TC drive away awning is ideal for anyone who wants a large and versatile space on their outdoor holiday.
This awning boasts the option of space for two bedroom inner tents. Our inflatable AirBeam® technology means you can pitch this awning in a matter of minutes so you’ve got more time to enjoy your holiday. The pre-angled beams create ample height throughout and the Sentinel Signature Fabric is perfect for touring with your campervan, keeping your awning cool in the warmer months due to its breathable yet water repellent construction. It’s also made even easier with multiple attachment options and the roll away tunnel allows you to drive away, leaving your awning free-standing.
  • Optional Carpet Available – Give your awning all the comforts of home without compromising your outdoor experience
  • Optional Groundsheet Protector Available – Protects built in groundsheet from rough ground. Prevents awning base getting wet and dirty, allowing easier pitching, packing and storage
  • Optional SkyLiner Available – Internal roof liner to help reduce the effects of condensation and provide a thermal barrier in cold weather. Connects to SkyTrack with pre-attached SkyHooks
  • This awning has multiple additions available for enhanced functionality – Please check our additions table for more details
  • Adjustable Pegging Points – Allows awning to be pitched perfectly on uneven surfaces
  • Tunnel Adjustment Strap – Helps collect any excess material and creates a neater looking tunnel and a tighter fit to the vehicle
  • AirBeam® Pump Included – Double action pump that will rapidly inflate your AirBeam® Awning which comes complete with a pressure dial and handy carry bag
  • Inflatable AirBeam® Structure – With 10 years’ experience in AirBeam® technology, we are the leaders in pole free pitching. AirBeam® technology ensures your awning is erect within a matter of minutes allowing you more time to enjoy your holiday (Supplied with double action pump)
  • AirSpeed® Valve System and Easy Access Positioning – Designed by Vango to inflate your AirBeam®s with even less effort
  • AirZone Ventilation – High and low level ventilation panels combine to create a comfortable flow of air throughout the awning, which is essential for reducing condensation
  • Cable Entry Point – Neatly feed electrical cables into your awning allowing you to easily keep your camping appliances powered
  • Great for Continental Use – Breathable fabric helps to regulate temperature inside your awning
  • Covered Entry – Gives a sheltered entrance into your awning, which prevents rain from dripping into the living area
  • Diamond Pro Windows – 67% thicker than our Diamond Clear windows, they provide additional insulation and clearer views
  • Drive Away – Using the addition of a Drive Away Kit, detach the tunnel area of your awning from your vehicle and roll it away leaving your awning free standing as you explore for the day. Keep a note of your parking position for when you return and re-attach the awning to your vehicle
  • Easy Access Doors – A flat entry access door creates easy access for wheelchairs, prams and people with reduced mobility
  • Easypack Carry Bag – Oversized carry bag to make it easier to pack the awning away
  • Fully Wind & Rain Tested – Tested with wind and heavy rainfall to the European standard EN5912
  • High Visibility Guylines – High visibility lower half to prevent tripping hazards and ensure stability in high winds
  • Line-Lok® Guyline Runners – The Line-Lok® tensioner locks guylines securely in tension, is easy to release and will give a high performance in all conditions
  • Multiple Vehicle Attachment Methods – All our awnings come with pre-attached 6mm kador, 8M over vehicle straps, roof bar attachment tabs and sleeve for pole & clamp kit system. This ensures our awnings are compatible with any vehicle
  • Pre-angled Beams – Achieve greater internal space than with a standard curve. Provides effective bracing against winds
  • Reflective Webbing – Picks up torchlight so the pegging points are easily spotted in low light conditions
  • Roll Away Connecting Tunnel – Detach your awning when you drive away for the day, simply roll back the tunnel and toggle it to secure
  • Secondary Mesh Doors – Fitted with internal mesh fly screen for bug-free ventilation
  • Sentinel Signature Fabric – Combines the leading properties of both cotton and polyester to create a rich polycotton fabric which is breathable and easy to maintain. Sentinel Signature is a high-quality fabric that is luxurious to the touch, robust and durable
  • Fully Sewn-in Groundsheet – Groundsheet is attached to the flysheet with an external storm skirt to provide a bug and draught free environment
  • Side Attachment – Awning attaches to your van with a side attachment to ensure you are always facing the view wherever you go
  • Skylight Windows – Windows which run along the roof line of the awning to enhance light during the day and for star gazing at night
  • SkyTrack II® – A flexible hanging system which allows you to easily attach lighting, storage or SkyLiners. The SkyTrack system allows you to customise your awning to suit your needs. (SkyHooks included)
  • Steel Rock Pegs Included – Pegs are strong, durable and can be used on more challenging terrain. Supplied with a handy carry bag
  • SuperBeams™ – Larger diameter beams providing additional structure and stability to the awning
  • Supplied with Pack of 10 Skyhooks – Simply slide on to the SkyTrack® System to hang storage or lights
  • TBS®II Tension Band System – Ensures awning performs in adverse conditions, especially in strong, changeable winds. When tensioned, the bands brace the beam or pole at 3 points and prevent sideways movement. Adjust TBS®II to remove slack. Do not over tension, as this may deform the poles. Can be stowed away in calm weather
  • Two Doors in Tunnel Attachment to Vehicle – For convenient access to the front or back of your vehicle
  • Touring Awning – This awning is designed for touring use; it is not designed for static or long-term seasonal pitching as extensive exposure to UV light will cause accelerated fabric degradation. UV degradation is not covered under the warranty. However, under normal holiday use your awning will give long service
  • Zipped Privacy Curtains – Simple and quick to use, zip curtains allow varying levels of opening or simply roll down and secure away
Data
  • Weight: 35.6kg
  • Packsize: L78.0 x H45.0 x W49.0cm
  • Pitching Time: 12 mins
  • Awning Size: Low
  • Kador Adjustable Height: 180-210cm
  • Weight without Accessories: 30.1kg
AWRGALLTCC3YTDR
Weight 36 kg
Dimensions 78 × 49 × 45 cm
Vango
Reviews (1)
1 review for Vango Galli Air TC Low Drive Away Awning Breathable Polycotton
  1. Andrew Lines (verified owner)
    Very pleased with this awning and it was worth paying extra for the superior fabric used in the Rhône. It is spacious and it hot weather surprisingly cool. Despite various you tube videos saying it can be erected in 15 minutes, took us ages! However, with practice I am sure we will improve! We found it difficult to get it back into the bag, followed the instructions to the letter. Not helped because this awning is heavy due to the weight and quality of the fabric. Worth buying the footprint groundsheet. Easy to attach to the van using the van awning 6mm channel and relatively secure to stop our dogs sneaking out. We have also bought the Kela V for when we go on overnight / shorter trips when we don’t need so much space. Overall the Rhone is a great awning but it is heavy and I would say not as easy at it looks to erect.
Add a review
You may also like…
  • Vango Drive Away Awning Kit 6mm to 6mm (3m Length)
£1,399.00 Inc VAT
Discount Code - SALE10
    SUBSCRIBE
