Kampa SabreLink 48 LED Lighting System 12v/240v – Starter Kit
£32.99 Inc VAT
In stock
Found this item cheaper?
Kampa SabreLink 48 System – Starter kit
An exciting new accessory for your tent, the SabreLink™ lighting system ensures you’re never in the dark. The system allows you to link up to three lights together.
Each system is controlled using a remote control that allows you to switch the lights on and off and also dim and brighten them. The lights can be hung using the carabiner and velcro fitting options provided.
- Avaliable as starter and add-on kits
- Up to three lights can link together
- Operated using a remote control
- Brightness can be adjusted
- Suitable for tents and awnings
- 48 super bright LED bulbs – never need replacing
- 80 cm long
- 5 metre cable (starter kit)
- 3 metre cable (add-on)
- Complete with mains and 12V adaptor in starter kit (UK and EURO plug versions available)
- Carabiner clips and velcro included
9120000345
Weight | 1.25 kg |
Dimensions | 20 × 20 × 105 cm |
