Kampa Sprint Awning Footprint Ground Sheet 257cm x 153cm
£4.99 Inc VAT
In stock
Found this item cheaper?Kampa Sprint Awning Footprint Ground Sheet 257cm x 153cm. The tailored footprint groundsheet that is compatible for the Kampa Sprint Drive Away Awning. This is a heavy-duty PE groundsheet that you’ll peg down, directly onto the ground first, that marks out your intended pitching position for your Kampa Sprint Driveaway Awning. This gives you a base to unpack your awning which will help you to keep your awning clean, and also saves you from muddy knees!
Once your drive-away awning is pitched this footprint groundsheet will serve to reduce water ingress into your awning’s living space and protects the awning’s groundsheet from stones, thorns and other sharp hazards. To maintain your awning for many years to follow, the footprint groundsheet is the recommended awning accessory.
9120002000
- Wipes clean for ease and convenience
- Non-breathable fabric reduces moisture when pitched on wet ground
- Carry bag included for easy storage and transport
Specifications
- Dimensions product depth 1550 mm
- Dimensions product height 2 mm
- Dimensions product width 2600 mm
- Net weight 0.74 kg
Weight | 1.5 kg |
Dimensions | 46 × 50 × 20 cm |
