VW California
Caravan
Drive-Away Awnings
Tents
Lifestyle Mini Portable 4.2kW Calor Gas Cabinet Heater
Lifestyle Mini Portable 4.2kW Calor Gas Cabinet Heater – Black
£109.99 Inc VAT
Only 1 left in stock
Found this item cheaper?
One of the most popular Lifestyle indoor heaters in a sleek black.
The Lifestyle Mini Heatforce is a popular choice for effective indoor spot heating. With its portable scale and castors, this heater is practically portable and storable.
This space-saving spot heater is half the size of a standard portable indoor heater yet continues to offer a generous 4.2kW heat output.
The portable heater that packs a punch
  • 12 month Lifestyle warranty
  • Portable, space-saving size
  • Powerful 4.2kW max heat output
  • 3 variable heat settings
  • 7kg Butane gas cylinder storage
  • Flame Failure Device
  • ODS (Oxygen Depletion System)
  • Castors for enhanced portability
  • Complete with hose and Butane regulator
Specifications
HEAT OUTPUT: Width: 4.2 kW
HEAT SETTINGS RANGE: 1.5 kW – 4.2 kW
CYLINDER SIZE: 7 kg
GAS TYPE: Butane
DIMENSIONS: Width: 42 cms | Depth (with back support): 43 cms | Depth (without back support): 27 cms |Height: 59 cms
505-120
Does not come with gas bottle.
Weight 1.2 kg
Be the first to review “Lifestyle Mini Portable 4.2kW Calor Gas Cabinet Heater – Black”
You may also like…
  • Kampa Cuboid 230v 750/1500w PTC Compact Fan Heater
£109.99 Inc VAT
