Milenco Door Locks improve the security of your recreational vehicle with this robust high-quality design.
- Good mechanical protection combined with a lock that has countermeasures to prevent opening by bump keys.
- High strength design that screws into the door frame on the recreational vehicle.
- Requires no inside space for mounting but needs a door frame gap of 5mm minimum.
- Can be locked in both open and closed positions.
- Please ensure you make a note of your key number.
Weight | 0.6 kg |
Reviews (1)
1 review for Milenco Door Frame Lock
Joanne Bromwich (verified owner) –
No fitting instructions inside the box, but my Dad fitted it, who had already fitted one to his caravan. Easy to use once fitted, locks by simply pushing the button in. (So make sure you don’t leave the key inside the caravan)
