VW California
Caravan
Drive-Away Awnings
Tents
Sale!
Outdoor Revolution 12V DC Electric Air Frame Inflator
£89.95 Inc VAT
In stock
Found this item cheaper?
The Outdoor Revolution 12V DC Electric Air Frame Inflator is a compact high quality, reliable high-pressure air pump designed specifically to inflate modern air tents and SUP’s up to a maximum pressure of 18psi. Powerful and effortless, this fantastic accessory is powered by connecting it to a 12V DC output socket.
An adjustable automatic PSI cut-off point eliminates the risk of overinflation, we have implemented a Simple twist dial indicator, which allows you to effortlessly monitor the pressure and pre-set your desired PSI.
  • Power: 12v DC vehicle cigarette socket
  • Max pressure: 18psi
  • 2.5m electric power cable with cigarette lighter plug
  • 1.7m high-quality air hose (EDPM), 20mm Diameter
Specifics
  • Weight 1.5kg
  • Size 24.5cm x 10cm x 11.5cm
PUMP2100
Weight 3.75 kg
Dimensions 45 × 24 × 16 cm
Outdoor Revolution
Manufacturer of premium caravan awnings, drive away awnings, family tents, canopy extensions, gazebo shelters and camping accessories.
Be the first to review “Outdoor Revolution 12V DC Electric Air Frame Inflator”
£89.95 Inc VAT
