Outdoor Revolution Movelite Canopy T2R / T3E / T4E
£119.00 Inc VAT
Only 1 left in stock
Found this item cheaper?The coordinating Movelite Canopy zips onto the front of the Movelite T2R, Movelite T3E and Movelite T4E drive away awnings to deliver a useful porch extension. Constructed using a robust steel pole, this accessory is the perfect addition to your awning, providing essential shade from the sun and shelter from the elements in adverse weather conditions, allowing you to kick back and enjoy some al fresco relaxation. This Canopy can be used as well as the Movelite Porch Door (T3E & T4E only), and can also be used in conjunction with the Movelite Canopy Retro Connector to fit directly into the 6mm awning channel on your vehicle.
The Movelite Canopy is pitched simply using a robust steel pole, there is a heavy-duty zip to attach the canopy to the awning along with a weatherproof baffle. Storm straps hold the tension & secure the canopy in position while a ground webbing system keeps the pole standing as it should.
ORDA2009
- 240HDE Hex Lightweight polyester fabric
- Pre angled heavy duty steel pole
- Zip on weather proof attachment system
- Ground webbing spacer system
- Designed to fit the 2022 Movelite T2R, T3E & T4E
- Includes peg set, storm straps and carry bag
Specifications
- Total Weight 3.48kg
- Pack Size 73x14x8cm
- Footprint 310 x 180cm
