VW California
Caravan
Drive-Away Awnings
Tents
Sale!
Outwell Coolbag Petrel S – Dark Blue
£4.50 Inc VAT
Only 2 left in stock
Found this item cheaper?
The Outwell Petrel S in dark blue is a handy, compact size for when you want to travel lighter. It’s ideal for snacks, kid’s packed lunches or solo days out. The large U-shaped opening gives easy access to the contents, which will stay cool for 7 hours with an 800ml Outwell Ice Block. This fits perfectly into the internal lid pockets. It’s also easy to clean and carry.
  • Shoulder strap can be adjusted into a carry handle
  • Large U-shape top opening
  • Hook and loop compression straps for small pack size when not in use
  • External front zip pocket
  • Internal lid mesh pockets designed to fit an ice block
  • Voluminous compartment
  • Water resistant loose liner for easy cleaning
  • 6mm foam
  • Insulation tested to BS EN12546-2:2000 – stays cool for 7 hours using a 800ml Ice Block
Specifications
  • Fabric:300D 100% polyester, PEVA lining
  • Size:23 x 16 x 18 cm (WxDxH)
  • Volume:6 L
  • Colour:Navy Night
  • Weight:0.3 kg
590151
Frequently bought together
Weight 8.5 kg
Dimensions 66 × 42 × 48 cm
Outwell
Outwell the INNOVATIVE FAMILY CAMPING. Tents, vehicle awnings, camping furniture, and accessories.
Be the first to review “Outwell Coolbag Petrel S – Dark Blue”
£4.50 Inc VAT
