VW California
Caravan
Drive-Away Awnings
Tents
Sale!
Outwell Corte Gas Grill BBQ & Stove
£109.00 Inc VAT
In stock
Found this item cheaper?
The king of portable BBQs, the cast iron Corte Gas Grill is a regal mix of style, strength and functionality. Perfect for all weathers, it’s easy to rustle up alfresco feasts on the large grill with variable heat control. The removable side tables are great for resting food and utensils, and there’s a drip tray base for easier cleaning. Takes larger LPG gas cylinders.
  • Stainless steel burner
  • Two removable side tables
  • Heat resistant lid handle
  • Temperature gauge
  • Variable heat control
  • Material: Steel / Chrome plated steel
Specs
Size: 94 x 42 x 41 cm (WxDxH)
Source: LPG gas cylinders (28-30 / 37 mbar regulator and hose ID 8-11 mm required)
Output: 3400 W
Colour: Grey
Pack size: 69.5 x 43.4 x 38 cm
Weight: 7.56 kg
650796
Outwell
Outwell the INNOVATIVE FAMILY CAMPING. Tents, vehicle awnings, camping furniture, and accessories.
Be the first to review “Outwell Corte Gas Grill BBQ & Stove”
You may also like…
£109.00 Inc VAT
