Outwell Mensa Mains 3-Way Roller Kit With USB Ports and Light
£62.99 Inc VAT
Only 2 left in stock
Found this item cheaper?Outwell Mensa Mains 3-Way Roller Kit With USB Ports and Light –
The Mensa Mains from Outwell is ideal for those not wanting to sacrifice using their electronic devices when camping. With a simple connection with your campsite electrical hookup you can simply plug up to 3 mains powered appliances into the Outwell Mensa roller unit to charge, power and use them exactly as you would do at home.
The Mensa mains unit also includes a handy LED light, which is perfect for those who don’t want to fiddle at night with wires and the 2 USB ports are ideal for those wanting to plug in and charge their smartphones or other mobile devices from the comfort of their own tent.
Outwell mains roller kits have all been designed with the main priority of family safety, closely followed by reliability and convenience to ensure you can easily use any mains powered device whilst on the campsite. The Outwell Mensa Mains 3-Way Roller Kit With USB Ports and Light is a perfect solution for all electrical needs, such as charging, boiling the kettle, toasting some bread or watching some TV.
- 15m cable
- Mains plug easy to site post
- Polarity warning light
- CE approved
- RCD & MBC protected with build in circuit breaker
- Three Uk sockets
- 3G1.5 cable
- IP44 – dust and splash proof
- Practical roll-up reel
- RCD (resdual current device) – for best protection
- Two USB ports for recharging tablets, smart phones etc
- Built in 74 LED light with 1 LED night light
Weight | 4.5 kg |
Dimensions | 32 × 22 × 33 cm |
