Please Note: OUR ONLINE STORE IS RUNNING AS USUAL + FREE UK DELIVERY FOR ORDERS OVER £75 & EXTENDED RETURNS.
Longer than normal delays on Comfortz products due to family illness
Free UK Delivery
Outwell Milestone Dash Drive Away Awning New For 2020
£349.00 Inc VAT
Only 1 left in stock
New For 2020
Outwell Milestone Dash small lightweight drive away awning ideal for smaller pitches and having the smallest packed size of all Outwell motorhome awnings, the dome-style Milestone Dash drive-away is perfect for touring. It is easily and quickly attached to campervans with a height range of 175cm-200cm thanks to the Access Zone that features internal buckled straps for height adjustment. The zone also provides doors either side for added options to the fold flat front door that is backed by insect-proof mesh for carefree undercover relaxation. Web storm straps are used to enhance stability provided by the fibreglass poles in windy conditions. Optional inner tent available.
  • 175cm-200cm attachment height
  •  7mm/5mm double bead
  •  Large front door with additional insect mesh screen
  •  Large rear opening for easy use of the Link Access Zone
  • Spacious living area with large tinted windows for a light-filled interior with toggle-up curtains for privacy
  •  Fully seam-sealed flysheet for maximum protection from the elements
  •  Pre-attached luminous guylines for convenience and fast pitching
  •  Adjustable pegging points for pitching flexibility
  •  Heavy duty Outwell zips are easy to use, running securely and freely
  •  Groundsheet for Link Access Zone with built-in draught excluder skirt
  •  HookTrack System for versatile positioning of lights and items up to 1.5kg
Specs
  • Flysheet: Outtex® 3000 Select, 100% polyester
  • Hydrostatic Head: 3000 mm
  • Sleeps: 2
  • Roof connection length: 250 cm
  • Attachment height: 175 – 200 cm
  • Bead thickness: 7 mm / 5 mm
  • Poles: Duratec fibreglass 12.5 mm
  • Floor: Double-coated waterproof polyethylene, 100% polyethylene
  • Pack size: 78 x 36 x 25 cm
  • Weight: 11.9 kg
  • Awning Type: Drive-Away
111099
Outwell
Be the first to review “Outwell Milestone Dash Drive Away Awning New For 2020”
£349.00 Inc VAT
Would you like a Discount Code?
Subscribe to our newsletter now to get free discount coupon code. Don't miss out!
    SUBSCRIBE
