Outwell 5m Strong Windbreak – Elegant/Vineyard Green
£38.99 Inc VAT
In stock
Found this item cheaper?Outwell 5m Strong Windbreak – Elegant/Vineyard Green
Large enough for the whole family and their deckchairs, the Outwell Windscreen Elegant Green provides a lengthy 5m of wind protection. The four fabric sections are 125cm high and a handy PVC ‘sneak peak’ window at the top lets you keep an eye on the kids. The windscreen is held in place by strong 16mm spring-linked poles and secured by ground spikes, steel pegs and luminous guylines.
In a beautiful green colour, this windbreak can also work when stealth camping as it blends into the surrounding areas.
- 3 lightweight sections
- Embossed fabric
- Lookout windows
- Extra durable pole sleeves
- Luminous guylines
- Ground spikes
- Flysheet: Outtex® 3000 Select, 100% polyester
- Poles: Steel poles 16 mm, spring linked
- Colour: Vineyard Green
- Pack size: 49 x 9 cm
- Weight: 2.6 kg
111217
Weight | 3.2 kg |
Dimensions | 65 × 20 × 15 cm |
2 reviews for Outwell 5m Strong Windbreak – Elegant/Vineyard Green
Janine (verified owner) –
Lovely colour and good size for privacy around wind-out awning, stopped every passer by from staring in but allowed nosey New Forest Ponies safe passage under the awning as seemed to be their favoured route!
Michael Burdus (verified owner) –
Typically decent Outwell product. Poles appear robust. Guy ropes take up a bit of space when erected, but stood up nicely to the strong winds. Compact when stowed.
