VW California
Caravan
Drive-Away Awnings
Tents
Quest Barbuda Low Wattage Ceramic Compact Heater
£17.99 Inc VAT
Out of stock
Email Me When Back in Stock
The Barbuda might be a small lightweight heater but it packs a mighty punch with its premium PTC (Positive Temperature Coefficient) heating element. Thanks to the premium heating elements the heater is extremely quick to warm up, giving off heat faster than many others. The built in ant-tip security cut off is there in case of accidents. If this heater falls over the cut out switch will turn the heat off helping to minimise damage and potential fires. The overheat cut out does the same if the heater gets too hot. The power indicator helps as it allows you to easily see if there is power to the unit alerting you so you can turn it off when you no longer need it. It is extremely lightweight making it easy to carry and the compact size makes it even easier, plus easy to store away when not in use. This is a low wattage heater so it draws less electric than a standard heater. This means that is cheaper to run and far less likely to trip your site electric supply when used on any number of sites. Some sites only allow low wattage items so this is allowed on these sites whereas a standard heater would not be.
  • PTC heating element
  • Low wattage
  • Quick to heat up
  • Anti-tip security cut off
  • Overheat security cut off
  • Power indicator
  • Lightweight and portable
  • Specs
    Size: 12.5 x 11.7 x 18.5 cm.
    Weight: 500 g.
    Voltage: 230v
    Frequency: 50/60 Hz
    Wattage: 500W
    E0092
    Weight 2.1 kg
    Dimensions 28 × 32 × 15 cm
    Quest
    Quest Leisure Caravan, Camping & Garden Centre supplier of all your accessories needs.
    Be the first to review “Quest Barbuda Low Wattage Ceramic Compact Heater”
    £17.99 Inc VAT
