VW California
Caravan
Drive-Away Awnings
Tents
Quest Stick Table
£6.99 Inc VAT
Only 2 left in stock
Found this item cheaper?
Lightweight and easy to use stick table. Non-slip cover on table and table leg can be removed and stored under the table when not in use. Steel shaft with a pointed end to make it easy to stick into the ground and a solid plastic top.
  • Lightweight.
  • Steel Shaft.
  • Non-Slip Cover.
  • Easy to Store
Specifications
  • Shaft: Steel
  • Table Top: Solid Plastic.
  • Table Size: 25 x 25 cm.
  • Table Height: 40 cm.
  • Weight: 0.1 kg.
Colours may vary
o92000
Quest
Quest Leisure Caravan, Camping & Garden Centre supplier of all your accessories needs.
Be the first to review “Quest Stick Table”
You may also like…
  • Kampa Folding Strong Tub Chair - Midnight
Quest Stick Table
£6.99 Inc VAT
