VW California
Caravan
Drive-Away Awnings
Tents
RidgeMonkey Connect Multi-Purpose Mini Pan & Griddle
(1 customer review)
£16.99 Inc VAT
In stock
Found this item cheaper?
The Connect Multi-Purpose Mini Pan & Griddle Set features a deep-sided saucepan and shallow griddle plate. The set has been developed due to popular demand from people who love to cook up a tasty meal in the great outdoors, while also minimising the weight of items that they have to carry with them, whether that be anglers, campers, caravanners, or camper van enthusiasts.
The lid of the deeper pan can be easily removed to double up as a separate griddle pan, allowing you to cook two lots of food at once. The griddle pan is also interchangeable with the RidgeMonkey Connect Compact Sandwich Toaster.
The square shape and removable handles allow for easy storage. The Mini Pan & Griddle Set fits within the larger RidgeMonkey Multi-Purpose Pan & Griddle Set for easy storage and space saving
  • Market-leading Fluoropolymer non-stick coating
  • Lightweight die-cast aluminium pans
  • Ridged exterior for even heat transfer
  • Unique detachable hinge design
  • Neoprene pouch for handles included
  • Cool touch removable handles
  • Fully compatible with RidgeMonkey Connect Compact Sandwich Toaster
  • Square shape offers easy storage by reducing wasted space
  • Detachable multi-purpose lid, doubles as a standalone griddle pan
  • Can be used on all traditional stoves and direct heat sources, including open fires (not suitable for induction hobs)
  • Protected registered design
  • Approximate dimensions: 190mm x 155mm x 100mm
RM685
Ridgemonkey
RidgeMonkey, brings to market a range of products that make a difference to anglers, campers, and outdoor living.
Reviews (1)
1 review for RidgeMonkey Connect Multi-Purpose Mini Pan & Griddle
  1. Nigel Bradshaw (verified owner)
    It’s a perfect addition for the ridge monkey sandwich toaster , perfect for our small kitchen in the California
Add a review
You may also like…
£16.99 Inc VAT
