Free UK Delivery
RidgeMonkey Connect Multi-Purpose Pan & Griddle Set
(1 customer review)
£31.99 Inc VAT
Get it Wednesday! Choose next day delivery within
Get it Tuesday! Choose next day delivery within
In stock
Rustle up all kinds of adventurous cuisine with the RidgeMonkey Connect Multi-Purpose Pan & Griddle Set, featuring a deep-sided saucepan and a shallow griddle plate. With use of RidgeMonkey’s innovative detachable hinge design, the griddle plate doubles as a lid for the deep pan or alternatively both pans can be used independently – the choice is yours!
The market-leading fluoropolymer coating provides unrivalled non-stick qualities and the squared shape & removable handles allow for easy storage in any situation. What’s more, the pan and griddle plate are both fully compatible with the existing RidgeMonkey Connect Compact Sandwich Toaster XL giving you even more adaptability than ever before!
  • Lightweight die-cast aluminium pans
  • Fluoropolymer non-stick coating
  • Ridged exterior for even heat transfer
  • Cool touch removable handles with magnetic lock
  • Unique detachable hinge design
  • Fully compatible with the RidgeMonkey Connect Compact Sandwich Toaster XL
  • Can be used on all traditional stoves and direct heat sources (not suitable for induction hobs)
Product Specification
Approximate dimensions:
235mm (350mm with handle) x 205mm x 135mm
* Stove not included
Ridgemonkey
Reviews (1)
1 review for RidgeMonkey Connect Multi-Purpose Pan & Griddle Set
  1. johnwsbridges (verified owner)
    Got this to go with our other RidgeMonkey sandwich toaster xl, which is great for all sorts of cooking – not just a toasted sandwich.
    The lid to this can be used as a grill pan. Stores easily. Fits well on top of cooker.
Add a review
You may also like…
£31.99 Inc VAT
