RidgeMonkey Connect Compact Sandwich Toaster Inc Case & Utensils – Standard
£19.99 Inc VAT
In stock
The best just got even better!! The all new Ridge Monkey Sandwich Toaster features a unique detachable hinge system that allows the pans to be used independently if required, one-touch removable handles and a fluoropolymer non-stick coating that is second to none, the new RidgeMonkey Connect Compact Sandwich Toasters raise the cookware bar once again!! Perfect for preparing a variety of snacks from a humble toastie right the way through to a full meal and everything in between.
- Lightweight die-cast aluminium pans
- Fluoropolymer non-stick coating
- Ridged exterior for even heat transfer
- Cool touch removable handles with magnetic lock
- Unique detachable hinge design
- Sleek GunMetal Grey finish
- Can be used on all traditional stoves (not suitable for induction hobs)
- Full utensil set and neoprene case included
Standard 180mm (295mm with handle) x 155mm x 40mm
Optional Extra – Gorillabox https://vwcaliforniaclub.com/shop/product/ridgemonkey-gorillabox-toaster-case-standard
RM124
Ridgemonkey
Weight | 1.5 lbs |
Dimensions | 31 × 24 × 10 in |
Type | With Standard Case, With Free Gorilla Case – Worth £19.99 |
You may also like…
Related products
£19.99 Inc VAT
