RidgeMonkey Ecopower USB Heated Gas Canister Cover
£15.95 Inc VAT
Out of stock
Email Me When Back in StockPower your adventure with the RidgeMonkey EcoPower USB Heated Gas Canister Cover: designed to fit all common 440-500 size butane / propane mixture camping gas canisters, the USB-powered heater coil will gently warm your gas canister enabling efficient use of every last drop of fuel even in the coldest conditions. Weather-resistant wipe clean neoprene outer with elasticated spoon strap and zipped lower section. 5V 2A USB input provides extended runtime while remaining compatible with almost all common USB power sources.
- Gently warms gas canister for maximum efficiency
- 5V 2A input compatible with almost all USB power sources
- External on / off switch
- Weather-resistant wipe clean neoprene outer
- Elasticated spoon strap.
**USB POWERBANK NOT INCLUDED**
RM482
Weight | 0.45 kg |
Dimensions | 32 × 22 × 28 cm |
