Never waste a drop of water again. Pick the size ideal for you (5, 10, or 15 litres) and use the inclusive tap to immediately manage the water flow, it’s perfect for those one cup kettle fills. When finished, unscrew the removable tap and replace with the standard lid to create a water-tight seal for transport!!
- Robust HDPE body
- Interchangeable lid/tap system
- Comfortable carry handle
Specs
- 5L is 300 x 135 x 215mm
- 10L is 320 x 180 x 280mm
- 15L is H350 x D190 x W310mm
Ridgemonkey
Size | 5 Litre, 10 Litre, 15 Litre |
Reviews (1)
1 review for RidgeMonkey Heavy Duty Water Carrier with Tap
£11.99 – £17.99 Inc VAT
Andrew Evans (verified owner) –
Looks robust and caps and tap work well – don’t leak. It should last a long time. Only reasons for not giving 5 stars – it’s expensive for what it is!
