VW California
Caravan
Drive-Away Awnings
Tents
Ridgemonkey RM-Tec Orbit Double Tapered Mono – 10lb > 35lb (4.5kg > 15.9kg, 0.28mm > 0.57mm)
£37.99 Inc VAT
Get it Friday! Choose next day delivery within
Get it Thursday! Choose next day delivery within
Only 2 left in stock
SKU: 5056210610602 Category: Tag:
RM-Tec Orbit Double Tapered Mono is a specialist casting line with an integral tapered shock leader at each end for maximum distance: perfect for extreme range fishing or for venues that have traditional leader bans, along with naked chod, snag and zig fishing – the increased diameter of the leader section doubles as a strong, abrasion-resistant buffer and helps to reduce tangles when fishing with fine zig hooklinks. Featuring a 5m section of high strength, low stretch mono shock leader tapering down to the required diameter along the next 7m, the line can be reversed onto a spare spool to reveal the second taper should a situation occur in which it is necessary to re-spool.
  • Sinking monofilament
  • Unrivaled casting qualities
  • High abrasion resistance
  • Low stretch
  • Subtle Green colouration
  • 3x 300m double tapered lengths per spool
  • 10lb > 35lb (4.5kg > 15.9kg, 0.28mm > 0.57mm)
RM-T276
Ridgemonkey
Be the first to review “Ridgemonkey RM-Tec Orbit Double Tapered Mono – 10lb > 35lb (4.5kg > 15.9kg, 0.28mm > 0.57mm)”
You may also like…
£37.99 Inc VAT
