VW California
Caravan
Drive-Away Awnings
Tents
Ridgemonkey RM-Tec Transmit Spod & Marker Braid
£20.95 Inc VAT
Get it Friday! Choose next day delivery within
Get it Thursday! Choose next day delivery within
In stock
SKU: 5056210600511 Category: Tags: ,
A super tough, high-visibility floating braid designed especially for spodding, Spombing or marker work. Featuring low diameter and zero stretch, Transmit Spod & Marker Braid has excellent casting qualities.
RM-Tec Transmit Spod & Marker Braid is perfect for coping with the constant abuse from repeated casting with fully loaded spods when introducing large quantities of bait at range or continual feature finding. Zero stretch ensures super-accurate transmission from your marker setup back to the rod tip, a factor that is critical for finding the very best feeding areas in your chosen venue.
  • 0.28mm / 25lb/ 11.3kg braided mainline
  • 300m per spool
  • Hi-Vis Green
  • Zero stretch
RMT-190
Ridgemonkey
Be the first to review “Ridgemonkey RM-Tec Transmit Spod & Marker Braid”
£20.95 Inc VAT
