The Vault Lite IR180: RidgeMonkey’s most powerful & versatile portable light source so far, combining torchlight, floodlight and powerbank functions in a single compact IP67 water-resistant housing. Featuring a massive 5200mAh rechargeable internal battery, 180 lumen torchlight, three-colour variable brightness floodlight and 5V 2.1A USB powerbank output, the Vault Lite IR180 will keep your gadgets powered and illuminated for up to 240 hours from a single charge.
Completely controllable with the tactile onboard multi-function button or with the included infra-red wireless remote fob, the all new IR system improves range, reliability and responsiveness giving the Vault Lite IR180 the very best remote system in the range so far. The hardwearing bodyshell can be attached to any ferrous metal, awning or tent using the integral magnetic fittings & included backing plate while the fully water resistant IP67-certified construction means the Vault Lite IR180 can be used in all weather conditions without fear of dust or water ingress.
- 180 lumen torchlight
- Three colour floodlight: White, Red and Green
- Built-in 5200mAh rechargeable lithium-ion battery
- 5V 2.1A USB powerbank output
- Superfast USB-C charging port
- Smooth brightness control
- Infra-red wireless remote control
- IP67 dust and water-resistant casing
- Robust construction with sleek GunMetal Grey finish
- Magnetic fittings, hanging lanyards and adjustable bankstick adaptor included
RM481
Ridgemonkey
