VW California
Caravan
Drive-Away Awnings
Tents
Ridgemonkey Vault Tech Table
£89.99 Inc VAT
Get it Tuesday! Choose next day delivery within
In stock
All portable tables are the same, right?
Not when your portable table can power your electronics!! Featuring a removable, rechargeable 9500mAh battery and two high-power USB output ports, the RidgeMonkey Vault Tech Table can be used to charge, power or simply keep all your USB compatible devices topped up during your outdoor adventures.
  • 18W C-Smart USB-C Power Delivery input
  • 18W C-Smart USB-C Power Delivery output
  • 5V 2.4A USB-A output
  • Removable, rechargeable 9500mAh Li-ion battery
  • LED power display
  • Large wipe clean surface
  • Folding height adjustable legs
  • Large adjustable feet
  • Protected registered design
Includes
  • Vault Tech Table
  • Rechargeable 9500mAh battery
  • External Charging Dock
  • USB-A to Multi Out Cable
Approximate Dimensions
  • Folded: 480mm x 310mm x 75mm
  • Leg extension: 250mm – 360mm
  • Weight (excluding battery): 1900g
Approximate Charge Times
  • 18W or higher Power Delivery Adaptor and Power Delivery compatible cable: 3.5-4 hours
  • 5V 2A USB power supply: 4.5-5 hours
  • 5V 1A USB power supply: 8-9 hours
  • External Tech Battery Charging Dock with Power Delivery or 5V 2A USB power supply: 4.5-5 hours
  • External Tech Battery Charging Dock with 5V 1A USB power supply: 8-9 hours
Approximate Charge Capacity
  • Extra-large high-end ‘plus’ smartphone EG Galaxy S10+, iPhone 11 Pro Max, Hauwei P30 approx charges (per battery): 1.5-2
  • Large high-end smartphone EG Galaxy S10, iPhone 11 Pro, Hauwei P20 approx charges (per battery): 1.5-2.5
  • Medium sized mid-range smartphone EG Galaxy S10e, iPhone 11, Hauwei P10 approx charges (per battery): 2-2.5
  • Mid-range older device EG Galaxy A3, iPhone 8 approx charges (per battery): 3.5-4
Accessories pictured, not included.
Ridgemonkey
Be the first to review “Ridgemonkey Vault Tech Table”
You may also like…
£89.99 Inc VAT
