Make dead batteries a thing of the past with the VRH150 USB Rechargeable Headtorch: alongside the twin colour output and variable brightness levels, the days of fumbling around in the dark looking for replacement batteries are gone – simply connect to any USB charger to top up the internal lithium-ion cell while using the built in power display to ensure you never run out of juice. Featuring a hard wearing rubberised outer and IP64 water resistance, the VRH150 offers market-leading headtorch design and functionality in a compact, simple to use package.
Product Features
- Triple High Powered LED output
- Dual colour, variable brightness:30-160 lumens
- Five beam options to suit all situations
- High capacity 1400mAh lithium-ion battery
- Quad LED power display
- Compatible with all common 5v USB charge adaptors
- Simple push button control
- IP64 water & dust resistance
- Dual orientation with 90 degree tilt function and twin on/off buttons
- Optional GorillaBox Tech Case available
Product Specification
- Protected registered design
- Charge time: 3-3.5 hours
- Battery life @ 15C: up to 80 hours (dependent on setting)
Approximate Dimensions: H40mm x W60mm x D50mm (without strap)
Strap folded approx 25mm
Approximate strap length: 50cm to 65cm (fully elasticated)
RMT HT 150
Ridgemonkey
