The VRH300 USB Rechargeable Headtorch’s meticulous design makes it the ideal choice for fishing, trekking, or camping.
Encased in a nifty rubberised shell, the VHR300 is not only durable – it is also water and dust resistant. In addition to looking great, the VRH300 has a clever dual-orientation design. There is no upside down. No matter which way you put it on – you can’t go wrong!
Green is the new red: the VHR300 emits a powerful green light that is adjustable to your preferences. Because the human eye is more receptive to green light than red, you’ll retain great night vision AND illumination clarity. Your eyes will love you for it.
The internal lithium polymer cell battery is fully rechargeable and compatible with all USB chargers. Forget about batteries, the four step power display will ensure you are never left in the dark.
Product Features
- Triple high powered LED output
- Dual colour, variable brightness: 50-200 lumens
- Five beam options to suit all situations
- High capacity 2000mah lithium polymer battery
- Quad LED power display
- Compatible with all common 5v USB charge adaptors
- Simple push button control
- IP64 water & dust resistance
- Dual orientation with 90 degree tilt function and twin on/off buttons
- Protected registered design
- Charge time: 4-5 hours
- Battery life @ 15C: up to 90 hours (dependent on setting)
- Optional GorillaBox Tech Case available
Product Specification
Approximate Dimensions: H44mm x W65mm x D52mm (without strap)
Strap folded approx 35mm
Approximate strap length: 55cm to 65cm (fully elasticated)
RM HT6
Ridgemonkey
