VW California
Caravan
Drive-Away Awnings
Tents
RidgeMonkey VRH300X USB Rechargeable Headtorch
£49.99 Inc VAT
Out of stock
Email Me When Back in Stock
SKU: 5056210622834 Categories: , , Tag:
Encased in a nifty rubberised shell, the VRH300X USB Rechargeable Headtorch is not only durable, it is water and dust resistant too. The VRH300X features twin colour adjustable brightness, ranging from 50-200 lumens. The headtorch also features a clever night location setting which enables you to keep the headtorch on at 1% power, ensuring that you can easily find your headtorch in the dark
Long lasting and hard-wearing, the VRH300X USB Rechargeable Headtorch offers up to 360 hours of light from one single charge*. Adding to its list of practicalities, the VRH300X has a clever dual-orientation design which means that there is no upside down – no matter which way you put it on you can’t go wrong.
The VRH300X’s design and durability makes it the ideal choice for fishing, trekking, or camping.
*tested and achieved with the night location feature, using 1% power.
  • Adjustable white light beam
  • Adjustable green light beam (to help retain night vision)
  • IP64 water and dust resistant
  • Dual orientation
  • Night location allows you to find your headtorch in the dark
  • Up to 360 hours of light from one charge*
Specifications
  • Triple high powered LED output
  • High capacity 2000mah lithium polymer battery
  • Twin colour, variable brightness: 50-200 lumens
  • Five beam options to suit all situations: low white/green, medium white/green, high white
  • Simple push button control
  • Night location feature
  • EUIPO registered design
  • Charge time: 4-5 hours
  • Battery life @ 15C: up to 360 hours (on night location mode) / up to 90 hours (dependent on mode)
  • H44mm x W65mm x D52mm (without strap)
  • Strap folded approx 35mm
  • Approximate strap length: 55cm to 65cm (fully elasticated)
RM HT 300X
Ridgemonkey
RidgeMonkey, brings to market a range of products that make a difference to anglers, campers, and outdoor living.
Be the first to review “RidgeMonkey VRH300X USB Rechargeable Headtorch”
You may also like…
£49.99 Inc VAT
