Introducing the Sevylor Tahaa (Taha’a) a two-person inflatable kayak that is named after the island in the French Polynesia. Just like the location the kayak is named after, the Tahaa Kayak is the ideal boat for those who seek relaxation. The Tahaa is a classical profiled kayak that is built for leisurely paddling, perfect to be enjoyed by the company of friends or family. It is a compact boat too which means the kayak can easily be store and transport in the boot of your car. It is also lightweight, weighing around 7.9kgs. This kayak kit includes two paddles.
The Sevylor Tahaa is a spacious kayak for its size, measuring 312cm (3.12m) in length by a width of 92cm (0.92m). Both seats are removal, easily converting the kayak into a single seater with plenty of space for a cool box along with other items you desire to travel with. At the bow and stern, the kayak is equipped with integrated spray deck, perfect for housing items that you wish to remain dry.
The craft is surprisingly stable to and this is with thanks to its I-beam constructed floor, this spreads the weight evenly which reduce wobble. This also gives the Tahaa its broad shape offering a roomy cockpit.
Includes 2 Oars
14875
- Broad shape offering excellent stability
- 2 removable, inflatable PVC Seats
- Integrated spray decks at bow and stern
- Boston, Mini Boston and Mini Double Lock valves for easy inflation and deflation
- Highly effective drainage system
- Inflatable side chambers
- Durable floor chamber with I-beam construction
- 2 oars are included within this kit
- 2 ergonomic carry handles for easy transportation
- SevyTest™: Allowing you to check pressure easily during inflation
- Pump sold seperately
Specifications
- Capacity: 2 Person
- Max Load Weight: 160kg
- Number of Inflatable Chambers: 3
- Inflated Dimensions: 312cm (Length) x 92cm (Width)
- Kayak Weight: 7.9kg
