Streetwize HD 1080p Rearview Dash Cam with Built In Microphone
£18.99 Inc VAT
In stock
Found this item cheaper?Designed to fit over the existing rearview mirror, eliminating the need to remove the factory-fitted rear view mirror from your vehicle.
Simply use the two straps that are on the rearview mirror dash cam and place it over the vehicle’s rearview mirror. Once the rearview mirror dash cam is in place, just connect it to the vehicle’s 12V accessory socket.
This rearview mirror dash cam has a built-in 3.5” display screen that shows real-time footage from the dash cam lens from the reverse side. The angle of the lens can be easily adjusted to ensure that it is facing straight ahead.
Can record up to 16 hours of high-quality footage on a 32GB SD card for providing video evidence in case of an accident. The device also has a mic for playing back footage with sound.
- 3.5” built-in display screen.
- Adjustable camera lens to ensure correct angle when recording footage.
- Designed to fit over most existing vehicle rearview mirrors.
- Can record AVI video in either 1080p, 720p and VGA.
- Supports micro SD cards from 4GB to 32GB.
- Built-in mic for recording audio.
- 12V connectivity.
SWREC10
