VW California
Caravan
Drive-Away Awnings
Tents
Summit LED Trio Lighting Set – Lantern, Torch & Headlight
£16.99 Inc VAT
Only 1 left in stock
All the items you need for lighting up your campsite set up, or for power cuts to use in an emergency at home . A functional 9 W LED lantern which is collapsible, a small 3W pocket torch and a useful headlight, making life easier than holding a torch. All battery operated, so ideal for the elderly and children to use.
The COB LED trio lighting set makes a great gift and covers most users lighting needs. The set is made up of a 9 Watt space saving collapsible lantern giving 360 degree illumination. For quick and easy operation, pull the lantern up for on and push down for off. The 3 Watt COB LED torch has a rubberised finish for a comfortable grip. To complete the set there is an adjustable headlight with an adjustable elasticated head strap.
  • Lantern, Torch & Headlight
  • Trio COB LED lighting set
  • 9 Watt COB LED collapsible lantern with 360degree illumination
  • 3 Watt COB LED rubberised torch
  • 3 Watt COB LED headlight with adjustable head strap
  • Lumens: lantern 600, torch 100, headlight 200
  • Burn time: lantern 8hr, torch 6hr, headlight 8hr
  • All IP54 rated
  • Battery Information: 3 x AA not included
  • Brand
    Summit
    Be the first to review “Summit LED Trio Lighting Set – Lantern, Torch & Headlight”
    £16.99 Inc VAT
