VW California
Caravan
Drive-Away Awnings
Tents
Sale!
Truma Ultraflow Water Pump Assembly – 800mm
£43.99 Inc VAT
Only 1 left in stock
Found this item cheaper?
The Truma Ultraflow Water Pump assembly is an ergonomic and simple solution that enables you to pump water into your vehicle from an external source such as your water carrier. The Ultraflow assembly connects conveniently with your Aquaroll or Waterhog and is compatible with both the Ultraflow Filter Housing and the Ultraflow Compact Housing. The water pump with ergonomically shaped pistol grip can be plugged into the filter or compact housing type connection, for use in your caravan and motorhome freshwater tank. Please note, do not run the pump dry as this may cause damage. This ultraflow submersible pump is available in an 800mm length, ideal to connect to your water carrier. The ideal water pump to use in your caravan or motorhome.
  • Ultraflow Water Pump assembly
  • Connects conveniently with your Aquaroll or Waterhog
  • Compatible with the Ultraflow Filter Housing
  • Compatible with the Ultraflow Compact Housing
  • Ergonomically shaped pistol grip
  • Ideal for use in a caravan and motorhome fresh water tanks
Specifications
  • Hose length: 800mm
  • Model reference: 46040-01
  • Barcode: 4052816014944
Weight 2.5 kg
Dimensions 39 × 39 × 29 cm
Truma
Truma is a German manufacturer of leisure products for caravans and motorhomes and in most caravans and motorhomes today.
Be the first to review “Truma Ultraflow Water Pump Assembly – 800mm”
£43.99 Inc VAT
