Vango Awning & Tent Universal Carpet 140 x 320cm – CP003
£28.99 Inc VAT
Only 1 left in stock
Found this item cheaper?Make your awning nice and cozy by adding warmth and comfort underfoot with a Vango Carpet. This universal carpet is 240 x 300 cm. Can be used in a number of tent and awning if you just want a bit of carpet in certain areas or if the area you have is 140 x 320cm.
This Vango Universal Carpet is 140 x 320 cm making it ideal for the following Vango Tents or drive-away awnings:
- Avington II 500
- Farley TC 500
- Alton Air 500
- Alton 500
- Cumbria 500
Please note this carpet is universal and is not made to fit these tents exact.
- Neutral colourway to suit all.
- Corner branding for easy positioning and identification
- Woven nylon top for durability
- Foam mid-layer for added insulation and comfort
- PE waterproof, non-slip base
- Easy to clean – Can be brushed, vacuumed or cleaned with a damp cloth if required
- Supplied with a handled carry bag
- Size: 240 x 300cm
CPQ000003W11G34
Frequently bought together
Weight | 2.25 kg |
Dimensions | 38 × 25 × 34 cm |
