VW California
Caravan
Drive-Away Awnings
Tents
Our top of the range Vango Blissful Double Airbed is like sleeping in your bed at home. The Blissful allows you to adjust the firmness of the bed to suit your needs with the Custom Comfort settings. You also have peace of mind that it will not deflate in the night with the Silent Top Up System, which intelligently detects any loss of air pressure. The Blissful has an indulgent soft surface and elevated height for added comfort, perfect for couples who desire an uninterrupted sleep at the campsite.
  • Coil Beam Construction – Offers great support whilst being extremely comfortable
  • Repair Patches Included – For use in emergencies
  • Raised edges – Enhances firmness and stability
  • Flocked PVC – Extra soft, comfortable flocked surface
  • Groundsheet Friendly – The smooth surface area ensures there is no damage to your groundsheet
  • Carry Bag Included – Convenient bag for storage and keeping the product clean
  • Mains Powered – Can be easily inflated at home or on the campsite using a UK mains plug
  • Inflates in 3 minutes – Fast inflation when you are looking forward to that good nights sleep
  • Silent Top Up – Appreciate an uninterrupted sleep thanks to the automatic top up pump, ensuring there is no loss of air pressure through the night
  • Custom Comfort – Create the comfortability you prefer by choosing from 3 different levels with the touch of a dial
  • Auto Switch Off – Once the airbed reaches its desired firmness, the pump automatically stops inflating, saving time during set up
  • Constant Comfort™ Pump – A smart pump technology that guarantees comfort by refilling the bed when it looses firmness
  • Maximum Loading Weight – 227kg/35st 10lbs
  • 3 Layer Height – Easier to descend onto and get up from
  • Self-Deflation Option – Simply turn the dial to deflate for quick and effortless deflation
Specifications
  • Weight: 8kg
  • Packsize: L35.5cm x H53.5cm x W17.5cm
  • Height: 46cm
  • Length: 191cm
  • Width: 140cm
  • Max Load: 227kg
Product Code: ABQBLISS N33A81
Weight 5 kg
Dimensions 37 × 31 × 10 cm
Vango
Be the first to review “Vango Blissful Double Airbed”
You may also like…
£119.99 Inc VAT
