VW California
Caravan
Drive-Away Awnings
Tents
Vango Faros III Air Low Drive Away Awning – New and Updated for 2024
£514.99 Inc VAT
Only 1 left in stock
Found this item cheaper?
Vango Faros III Air Low Drive Away Awning – Roof Rail Connection Height: 180-210cm
Coming in new for 2024, the Vango Faros III is an updated model of the previous well-known Vango Faros II. The main difference is that the 2024 version is now made out of the Sentinel Active 150D Fabric rather than the standard, meaning the fabric is a thicker and stronger fabric.
The Faros III Air Low is a lightweight, inflatable awning featuring Vangos Sentinel Active 150D quality fabric whilst ensuring a great compact pack size, ideal for short breaks away without taking up valuable storage space.
This campervan awning can be left freestanding whilst you head out for the day and then easily reattached upon your return thanks to its multi-attachment options and simple double-entry tunnel structure. The large front door with mesh panel creates a great living space making this awning the perfect addition to your vehicle on short breaks away.
The Vango Faros III Air Low includes: Airbeam Pump, Steel pegs, attached guylines and is fully wind and rain tested.
  • Sentinel Active 150D Fabric
  • Inflatable Airbeam Structure
  • Diamond Clear Windows
  • TBS II Tension Band System
  • Mesh Front Door
  • Bracer Pole Included
  • Easy Access Doors
  • Easy Pack Carry Bag
  • Toggled Privacy Curtains
  • Tunnel Adjustment Strap
  • Airzone Ventilation
  • Lantern Hanging Points
  • Roll Away Connection Tunnel
  • Fully Sewn-In Groundsheet
  • Clear Visibility Guylines
  • Two Doors in Tunnel Attachment
Specifications
  • Weight:13.9kg
  • Packsize:L 75cm x H 35cm x W 35cm
  • Pitching Time:7 mins
  • Awning Size:Low
  • Kador Adjustable Height:180-210cm
  • Height: 205cm
  • Length: 275cm
  • Depth: 290cm
AWUFAROAI000002
Please allow 3/5 Days delivery on this item.
Weight 10 kg
Dimensions 70 × 30 × 30 cm
Vango
Be the first to review “Vango Faros III Air Low Drive Away Awning – New and Updated for 2024”
You may also like…
  • Vango Footprint Tent Awning Ground Protection Sheet 3m x 2.45m
  • Vango Drive Away Awning Kit
  • Vango Drive Away Awning Kit 6mm to 6mm (3m Length)
£514.99 Inc VAT
