VW California
Caravan
Drive-Away Awnings
Tents
Sale!
Vango Footprint Tent Awning Ground Protection Sheet 3m x 2.45m
£8.99 Inc VAT
Only 2 left in stock
Found this item cheaper?
PLEASE NOTE: This can also fit the Vango Kela (just 25cm too wide), Outdoor Revolution Cayman Cuda (just 45cm too wide), Outdoor Revolution Movelite T2R (5cm too short in width and 10cm too short in length),
Help keep clean and protect your awning groundsheet by adding a Vango Footprint to your camping essentials. They are easy to remove and clean and will provide protection from small tears and holes from stones. An invaluable addition to extend the life of your awning. All Vango footprints are cut specifically for each model
Specifications
  • Marks out intended pitching position. Easy to move about before rolling tent out to pitch
  • Protects the groundsheet of your tent from stones, thorns and other hazards
  • Keeps tent groundsheet clean – Easier to pack up camp and saves cleaning tent
  • Uses durable 100% PE construction that will last and is easy to clean
  • Folds away into compact carry bag – Easy to transport and helps to keep tent clean
Fits
  • Siesta Air Low
  • Bondi Low
  • Byron Low
  • Elwood Air Low
GPQ000006B05Z01
GP006
Weight 2 kg
Dimensions 58 × 13 × 10 cm
Vango
Be the first to review “Vango Footprint Tent Awning Ground Protection Sheet 3m x 2.45m”
You may also like…
  • Vango Drive Away Awning Kit
  • Vango Drive Away Awning Kit 6mm to 6mm (3m Length)
£8.99 Inc VAT
